Page 5 of 5
Re: Project Jug
Posted: Sat Jun 08, 2013 9:30 pm
by Brunty
eefy wrote:Nice mate, but sure theres room for some more scaffolding poles in there somewhere ;)
That's the preview!
Re: Project Jug
Posted: Sat Jun 15, 2013 5:35 pm
by Brunty
This is how Custom Cages recommend fitting the main loop
It worked fairly well. It was a pain in the butt to get it back into place after welding the roof pieces though. Anyway -
Couple of evenings later...
This is the bulkhead and front suspension tower if you can't get your head around the angle ;)
Just waiting for the last images to back up from my phone :)
Re: Project Jug
Posted: Sat Jun 15, 2013 5:39 pm
by Brunty
And there they are. The last couple of pics of front triangulation bracing :)
Just got the near side triangulation pieces to go in and then weld up the holes. A few more holes to fill in the bulk head and the floor (I found one rust hole underneath some seam sealer!) and I can paint the inside :D
Re: Project Jug
Posted: Sat Aug 17, 2013 12:45 pm
by Brunty
Long time since last update, sorry The Interceptor, I shall try harder in future...
A photo montage to catch up a bit -
While I had the car upside down I decided to make a couple of axle stand points. (Imagine the pic upside down ;) )
I forgot to take pics of the rear underside after I'd done the cleaning up, so we jump to some sticking bits in. I'm needing the steering wheel and pedals in so I can work out where to put the seat.
Re: Project Jug
Posted: Mon Aug 19, 2013 4:54 pm
by eefy
bloody hell mate, you;ve been putting the hours in ther aint you!!!!!! looking good though :)
Re: Project Jug
Posted: Mon Nov 04, 2013 11:12 am
by treefingers
Looking great man, you've put a lot of work in so far!! How's the progress coming on at the moment?
I agree that the sealant really is a nightmare for welding! What are your engine plans?
Re: Project Jug
Posted: Mon Nov 04, 2013 11:31 am
by Brunty
In what available time I have (not much) I'm just checking the engine over. It's the same engine that was in Daz...
Re: Project Jug
Posted: Wed Mar 30, 2016 8:24 pm
by Brunty
Frequency of updates is appalling :(
I've had so little time to do much by the looks of it. I have managed to do some little bits though. I've started looking at doing the hydraulic clutch conversion on the standard cable clutch gearbox. It's been a bit fiddly as the master cylinder wants to foul part of the roll cage. Once I've got that sorted I can get on with a big brake improvement...
It means I can get rid of all the cross bulkhead linkage and servo :) It frees up a load of space under the bonnet. I need to get some more welding done though, no major problems.
Talking of welding, I'm removing the boot floor to recess in the alloy race fuel tank. I'm toying with various ideas, so will update later.
Re: Project Jug
Posted: Tue Dec 26, 2017 9:55 am
by Brunty
So, one year ago, I had some time free. I did, in fact, make a start on the brake bias pedal box. It was some time after doing this -
that I realised that this kit is designed to fit on the original mounting point of the brake servo :oops: Ah well, I was thinking about moving it all in front of the driver's seat anyway :lol:
I made a frame for the pedal box to bolt to.
Then put a skin over,
All trial fitted and hydraulically tested so I just need to strip it down and make it more presentable.
The engine will be coming back out for a rebuild as it's been so long since it ran so I'll get decent access, and all the clearances have been checked.
