Where to start?
Fatlemon
Where to start?
Post by Fatlemon » Fri Dec 23, 2011 3:38 pm
Courtesy of the boss letting us go early I manage to see my “new” car in daylight for the first time. Took some pictures (hopefully attached) then decided that she needed a wash.
Immediately broke down the things that need doing into three groups
Stopping. Need to sort out brakes
Going. Need to sort out idle speed (interesting when she is idling at 2000 rpm as an auto with poor brakes)
Body work. Leaking into boot through suspect boot seal and is the sun roof meant to lift by about ¼ inch when you shut the door. There is something amiss here as there are scratch marks on the sun roof.
So I have decided that tomorrow the garage is being sorted to allow me to get her inside so that no more water can get in and I can sort out the leaks and brakes before contemplating the going bit.
Fatlemon
Re: Where to start?
Post by Fatlemon » Fri Dec 23, 2011 3:40 pm
OK, not photo not attached, How is that done then :?:
Re: Where to start?
Post by Old Mac Rocco » Fri Dec 23, 2011 4:00 pm
Hi Fatlemon,
Have a look on here and it will give you some pointers on the pictures.
http://www.sciroccouk.co.uk/forum/viewt ... t+pictures
Any problems just ask.
Good luck.
Re: Where to start?
Post by Brunty » Fri Dec 23, 2011 6:14 pm
Moved to Project Diaries as that sounds more appropriate!
Fatlemon
Re: Where to start?
Post by Fatlemon » Fri Dec 23, 2011 8:05 pm
Brunty wrote:Moved to Project Diaries as that sounds more appropriate!
I don't intend to spend that long on it. :)
Re: Where to start?
Post by eefy » Fri Dec 23, 2011 10:47 pm
For the boot leak, have a look at the boot lock seal, thats what the problem was with mine :) there still available from VW
Re: Where to start?
Post by Brunty » Fri Dec 23, 2011 11:44 pm
eefy wrote:For the boot leak, have a look at the boot lock seal, thats what the problem was with mine :) there still available from VW
It also comes in through the main rubber seal, I've fixed some by removing it, cleaning it up and rotating it around 180 degrees.
Re: Where to start?
Good stuff :thumbup:
Re: Where to start?
Post by ianaudia4 » Fri Dec 23, 2011 11:55 pm
Oh no they're not mate!
Fatlemon
Re: Where to start?
Post by Fatlemon » Mon Dec 26, 2011 7:46 pm
Thanks for this one, its probably just saved me a lot of head scratching. The lock seal is as water proof as a sieve. :thumbup:
